Blackmobile wrote:go to a shop and have everything measured. people out there with 9+ wide wheels are either totally flush or sticking out. we can't run really agressive setups, our cars are not designed for it. 8.5 +35 is totally flush like said above. if you're slammed, i don't even think you could get away with that setup without some camber and tire stretching. at 9.5 +22 you're gonna have like an inch of wheel sticking out
Aggressive for us is not aggressive for other cars and vice versa. To my understanding you can make anything (not literally) fit with enough camber and stretch.
downedzephyr wrote:9.5 +22? that's extremely aggressive. i would expect lots of rubbing simply because 8.5 +35 sits pretty flush. if you're gonna run 9.5, i would say look into a +42 offset, or +35 with stretched tires. then again, i'm not exactly a wheel expert
Oilsink is running 8.5 +15 front and 9.5 + 15 rear with camber, bigger tires than me and no rubbing
8.5+35 is not flush from first hand experience. 8.5+27 is flush and coils are on lowest settings. No rubbing but my tires are small also.
mrodrig2 wrote:Regarding camber giving clearance, they are probably referring to clearance to the wheel arch, but on the other hand you may be losing interior clearance. There's no set calculation X degrees of camber yields Y mm of clearance. Maybe you can use that as a very rough idea, but its different for every car because wheel shrouds, fenders, wheel well shape, suspension components, etc aren't the same on every car.
Thanks. I know every car is different but everyone else must have figured it out some way other than PURE trial and error.
