robc10x »
https://forums.nicoclub.com/robc10x-u150507.html
Sat Feb 27, 2010 1:26 pm
After a search that came up empty, I figured it out myself. There may be a better way but this is quick and easy, and you'll save an hour of dealer labor and their cost on the part.
I ordered an Infiniti EX35 rear wiper blade from Infiniti Parts Warehouse. PN 287901BA0ACost me $15 to my door. You will need a 10mm wrench. With both hands, grasp the wiper arm at the base, and place both thumbs on the rounded base cover with your fingers on the edges of the cover underneath. This cover is only about 3" long. Gently lift and pull the cover off the base of the wiper arm. You will see a 10mm nut. Remove the nut. Your wiper arm is on a knurled stud. Do not pry or force the removal of the arm. Gently wiggle the arm and pull straight up.
Now that you have the arm assembly in your hands, hold it so that the arm is in your left hand and blade is in your right, upside down so that you see the spring and the underside of the wiper arm. Gently rotate the wiper blade assembly down and away from the arm with your right hand and it will snap off. Replace the wiper blade with the new one which simply snaps into place. Replace in reverse order. To ensure proper alignment on the rear window, hold the arm in the desired location with your right hand while you snug the nut into place. Replace the arm cover by gently sliding it over the nut and snapping it into place.
Have a beer and celebrate a small victory over the dealership. This is not the time to be ham-fisted as you are dealing with plastic parts. Don't force anything and it'll be a 5-7 minute job. Feel free to correct anything here, and I'll try and add pics tomorrow. Hope this helps somebody. If there is an easier method, feel free to correct me. With no tabs like the front wipers, I found it necessary to remove the arm so I could rotate the blade off of it.
