Hello
I have a problem about passenger side fog light. Mine is 2011 AWD.
Recently, one of my fog light passenger side started flickering then totally stop working. I thought the bulb is bad and purchased new LED bulb H11.Plug in but not working.
I checked fuse, good. And both side use this fuse as I learnt.
Go back check old bulb and new bulb, both good.
I removed small yellow cap in connector and test the voltage, the driver side is 11.8v, but passenger side is 1.35v only.
If I turn off fog light, I got 0.3v-0.4v reading from connector.
I checked the wiring diagram, it shows both side are just splitted from 1 wire group and connects to battery, relay controls them on/off.
Now I think here is 3 possiblities:
1. Connector (to bulb) itself is bad, inside rust causes huge resistnace so bulb cannot have enough voltage. = replace connector.
2. The wiring is thin/slim somewhere, not sure how to determine the defect part. But ususally even the cable is very slim, the voltage shuold not drop to 1.3v from 12v.
3. The end of wiring connector to battery is bad, but this cannot explain driver side is 12v.
I guess it does not related to relay... what should I do to fix it?
Please kindly share your idea Thank you,
