EX35 OEM Rim Specs...
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
What are the specs of the OEM - EX35 17" Rim ?
What are the specs of the OEM - EX35 18" Rim ?
EXceptional
Width Offset Hub Dia Bolt Pattern
EX-35 17x7.5 45MM 5x114.3
EX-35 18x8 47MM 5x114.3
06 G35 17x7 45MM ?? 5x114.3
18x7.5 45MM 5x114.3
06 G35C all 30-33 5x114.3
07+ G35 17x7.5 45MM 5x114.3
Sport F 18x7.5 45MM 5x114.3
Sport R 18x8.5 50MM 5x114.3
08 G37 18x8 43MM 5x114.3
Sport F 19x8.5 43MM 5x114.3
Sport R 19x9 45MM 5x114.3
07 FX-35 18x8 40MM 5x114.3
20x8 40MM 5x114.3
07 Murano 18x7.5 35MM 5x114.3
09 Murano 18x7.5 50MM 5x114.3
20x7.5 50MM 5x114.3
txgcoupe
Car: 2007 G35 Coupe/ 2010 EX35
G35's and G37's have staggered wheels.
So the winter in Alberta must be getting to you if you're answering your own posts. :biggrin:
John
EXceptional
txgcoupe wrote:So the winter in Alberta must be getting to you if you're answering your own posts.
John
Ya, it's dragging on.
I looked for a previous Thread/Post on this Subject... and couldn't find one.
Maybe I didn't look hard enough...
I'm actually looking at a set of 17" Rims for Winter Tires... and I wanted to make sure that they would work.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
