Not so - the ACTION published in the TSB is: "Back-Flush" the heater core to remove gray silicone debris. Also, this noise isn't related to operation over rough surfaces, but depends rather on engine RPM (presumably since that relates to the movement of coolant through the heater core).bttek wrote:True enough but I think that the TSB that you referenced was for a mechanical noise, not the creaking/ticking noise that some of us have experienced when driving the car over rough surfaces.
I know your symptom occurred over rough roads but drducati doesn't mention that at all.
Cheers,David
