What are you guys talking about? You can always shift from D mode to DS or Manual even when the car is moving at 55MPH .joser122588 wrote:I doubt you can do that, I personally wouldnt do it. At first when i drove in ds mode for the first time i let my foot off the gas like you would in a manual transmission to put the clutch in and then figured out i didnt have to do it. My first experience driving in DS mode was pretty fun. Now thats the only way i drive the EX.
You can shift from D mode to DS mode since the DS mode will rev match whatever RPM you are in in the D mode. (Is that what rev matching DS mode is for?) This is what the Infiniti trans w/ manual gear box is designed for.Try cruising at 55mph on D mode and shift it to DS. You`ll see it rev match your RPM and you end up on the nice RPM torque curve. This is very good in abrupt passing manuever, since it will extract all the torque and Horsepower right up to the redline before it shift. Just be very careful sometimes when coming from D mode to DS mode and decided to manually shift it. Always make sure you tap it up or (+) bec. sometimes you`ll find yourself taping it down and RPM over revvs the engine.The best thing about this transmission is that it has fool proof protection mode.Sometimes when using the manual mode, you won`t be able to upshift bec.the RPM is to low to upshift. Like when you are driving 10 MPH and shift it to 3rd or 4th gear- I think it won`t let you do it.302@12psi wrote:Can you shift into the differet modes while driving? Meaning can you be in D on the highway at 55 and shift into DS?
My question is do you have to downshift (while driving manual) when slowing down or does the transmission automatically does it for you???AWGD8 wrote:
From the Drive position, just pull the shifter left towards the driver, to where you would normally do manual shifting, BUT without shifting up or down, and you'll see the dash display change from D (Drive) to DS (Drive Sport).CaribMon71 wrote:Can someone please tell me how to engage or activate this mode?
Basically, the transmission is downshifting when the rpm could no longer hold that low speed of a travel. Although, the transmission already downshifted, it will stay more on the 2,500-3000k RPM for better torque anticipation or beginning of the torque curve. You might not notice it downshifting bec. it tries to rev match your speed. If your at 50MPH and cruising, the rpm will probably around 3k and if in 40 , 30, 20 or 10mph, it`s still be around 2.5k or 3k it will rev match your speed, and you might think it doesn`t downshifted.Cobra427 wrote:Question to all EX35 owners.
When I put the shifter in DS mode my transmission is not down shifting.which is contrary to what is stated in the NICO EX35 review and road test.
"DS mode wholly changes the temperament of the EX as it immediately drops you to 4th gear and begins to rev-match for better performance. "
Is this normal?
Ted
Nahhh .... I do that all the time. Running at 65 on D mode, then shift to DS mode to so I could blast to 85mph-90mph in a heartbeat.joser122588 wrote:I doubt you can do that, I personally wouldnt do it. At first when i drove in ds mode for the first time i let my foot off the gas like you would in a manual transmission to put the clutch in and then figured out i didnt have to do it. My first experience driving in DS mode was pretty fun. Now thats the only way i drive the EX.
