Im not sure if the QX50 offers paddle shifters now, I didnt see them in the showroom model I saw. The only new feature seemed to be the blind spot warning.mattderk wrote:I am curious if anyone has looked into the Q50 paddles as a "kit" ? Would the OEM steering column trim work out of the box...assuming the Q50 is close to the EX the time might be a perfect fit with no modification.
Has anyone checked the 2011 and newer vehicles for paddle mounts (no tapping /brackets required) ?
I do not believe the Q50/G steering wheel surround is the same as the QX50/EX. I ended up cutting my surround to install the paddles, I don't think it is very noticible, it looks like a casting mark on the plastic (I made a straight slit down from the top to the area I needed to trim out).mattderk wrote:I am curious if anyone has looked into the Q50 paddles as a "kit" ? Would the OEM steering column trim work out of the box...assuming the Q50 is close to the EX the time might be a perfect fit with no modification.
jrmotorsports55 wrote:I do not believe the Q50/G steering wheel surround is the same as the QX50/EX. I ended up cutting my surround to install the paddles, I don't think it is very noticible, it looks like a casting mark on the plastic (I made a straight slit down from the top to the area I needed to trim out).mattderk wrote:I am curious if anyone has looked into the Q50 paddles as a "kit" ? Would the OEM steering column trim work out of the box...assuming the Q50 is close to the EX the time might be a perfect fit with no modification.
Jason
Unless it's a dealer-installed option, the US version of the QX50 does not have paddle shifters as an option. Mine is fully loaded (AWD Journey with Tech) and does not have them, though I think the steering column has cutouts for the shifters (too lazy to go and check now).mattderk wrote:Damn .. I meant QX50 .. not Q50. I hate this new Q naming convention. Since I see the new QX50 lists paddle shifters on their website for features.
Check this video out. What are the circular holes in the steering column?mk15 wrote:There are no cutouts for paddle shifts on my QX50, not surprising since the QX50 is identical to the EX37.
Oh.. Derp! I thought the paddle shifters were mounted on the steering column, not the steering wheel. My bad.ralfp wrote:Check this video out. What are the circular holes in the steering column?mk15 wrote:There are no cutouts for paddle shifts on my QX50, not surprising since the QX50 is identical to the EX37.
Though I don't know if they're on the EX37 or QX50. Will take a look at the QX50 when the better half comes home.
The paddles do mount to the column, not the wheel. I do not know of any EX35/QX50 that offers them as an option, so you will need to cut a factory surround to install them. Also, from the original post, the newer models may not even have the provisions to mount them, so you may need to fab up mounts (my 08 had the mounting holes, so it was a straight install, I cannot verify for any other years).mk15 wrote:Oh.. Derp! I thought the paddle shifters were mounted on the steering column, not the steering wheel. My bad.I needs more coffee.
It depends on the car; I've driven cars where the paddles are mounted on the wheel. However, it seems like Infiniti's paddle shifters are column mounted. AFAIK the G, FX, and Q50 have them mounted to the column (e.g. this).jrmotorsports55 wrote:The paddles do mount to the column, not the wheel. .mk15 wrote:Oh.. Derp! I thought the paddle shifters were mounted on the steering column, not the steering wheel. My bad.I needs more coffee.
Infiniti should had simply called the EX series the G-hot hatch editionmikedooray wrote:Funny I was just discussing this my my friend (infiniti master mechanic) he said its a pretty simple and fairly cheap mod, all the wiring is there ready to go! he also was wondering why it didn't come as an option. My theory is..why would it, let's face it the EX is not "race" oriented if it were it would take away from the other models (sedan and coupe) this goes along with the same lines as decreasing HP even though it shares the same VQ35HR engine with the g35 but with 6-10 less ponies under the hood, and also taming the exhaust note about 2 decibels.
If I go ahead with this mod I will post photos of the process!
Infiniti should had simply called the EX series the G-hot hatch editionI would had still bought it.
Do the mod! Do it!
rex9271 wrote:I have some wire sets can fit EX(QX50) , 11~14 M(Q70) and 08~14FX(QX70)!
I also have some OEM brackets can be used on EX(QX50).
Terminals are 100% match to TH40FW-NH, they are as same as terminals on your car!
Connector with orange and black wires for (-)DOWN Shifter
Connector with green and black wires for (+)UP Shifter
Terminals for TH40FW-NH Connector
