Timmbo wrote:Make sure you relieve yourself and take a dump before you drive, that can drop a few pounds as well!
you would have more fun finding a used LS big block and a gutted car on the track than doing what you've done....
but if you're really serious about this....
get adjustable suspension/shocks/coilovers, w/e sticky tires you have now, get track compound tires, keep it on the track.....(honestly i dont care what backroad you drive on, its illegal and dangerous)better brakes, get stainless steel lines, remove your moon roof and have it re sheeted with lightweight magnesium, take out all the trim pieces, might as well remove the rear seats, passenger seat, all the extra engine pieces in the front, remove the grill, get TE-37's, go with meth injection, wrap everything in heat dissipating wraps,
but hey, that's only if you were a "TRUE car enthusiast"
you seem young, look, sorry for poking fun at you, but you drive a CUV. The fact that you track your CUV, is cool if... that's all the funds you currently have for.....but it's a CUV..and a heavy one at that.
now if you're talking about a nice lil weekend canyon run, touring around and relaxing, well then i can understand a bit better, tho again, you would probably be better off buying a used miata, gutting it and playing around with that...
anyway, if it's just for a nice spirited drive, I would lower suspension/coilover/shocks, get a BBK + SS lines, and invest in some VERY VERY nice high performance run flats so you can leave the spare at home, and attach them to 17" TE-37s..., the K&N filter is not a performance mod moreso than a convenience, but with ur +2 mod, this combo should prove to be quite spirited.
btw, 100+ octane fuel w/+2...arent you just asking for knocking?
and FYI, lowering your seats doesn't give you a better balance, unless you weight 0 lbs, what it DOES do is give you better visibility.
3/4 tank = fail, sorry, too heavy, keep it under 1/4, leave the extra fuel for somewhere you will pass later on
also probably should use 10w30 (are we 5w or 10w?)
the only valid points i will agree withVDC offTire pressure ~ but you should be checking this out with every weather change and about 1-2 weeks anywayA/C off
other than that, go take a big dump and take off all your clothes you might gain .01 WHP
