McAnally »
https://forums.nicoclub.com/mcanally-u292835.html
Thu Oct 24, 2019 3:14 pm
This is my first forum post. My 2008 EX35 stranded me over the weekend. Here are the events. I went to start the car and it acted as though it did not recognize the fob. The fob unlocked the car but I did not see the normal foot on break. I inserted in fob holder still nothing. I disconnected and reconnected the negative battery cable and was able to start the car. However, the CEL, AWD And slip indicator where illuminated additionally the dash lights would periodically go off and restart... like it was trying to reboot. I drove to the nearest Nissan dealer as it was Saturday they couldn't help until Monday. The car restarted no problem at the dealer but it still had the warning lights. On the drive back I decided to stop at O'Reilly's for a code read. En-route the car felt as though it had developed a hard shift. I got to O'Reilly's and shut off the car the clerk hooked up the code reader and could not connect to the cars system. The car would not restart, disconnecting the Neg would not work this time. I ended up disconnecting both cables and touching them together before reconnecting to battery. The car restarted acted as though nothing had happened performed normal and no system warning lights. I drove back about 2 miles to where we were staying told my son to grab his bags we are returning home. We packed the car and NO start, again like it did not recognize the fob. I gave up rented a car and drove 300+ miles home. Two potentially significant events occurred prior to the failure I had the battery replaced 2 days before the trip and the night before the failure I jumped another car. I am confident that the wires where not crossed during the jump off. My plan is to return and replace camshaft , crankshaft sensors, inspect the grounds and check harnesses for corrosion. I am concerned that I have an ECU/ECM issue and will likely have to go to the dealer . Sorry for the long read but so many odd or new items. Has anyone else experienced this? Any suggestions ? Thanks
