Mayhem_J30 wrote:Interesting fact about the engines Repo, I was unaware of that. Are they just turning up the boost a bit or sumptin
Here's the breakdown on the new Evo:
HP: I was wrong. It is 271hp at 6500rpmTQ: 273 ft/lb at 3500rpmCompression Ratio: 8.8:1Redline: 7000rpmBlock: Cast IronHead: AluminumValve Cover: MagnesiumBoost: 18psi@3500rpm (WOT) decreases to 16psi@6500rpm (WOT)Turbo: TD05HR-16G6-9.8T (small 16g)Sway Bars: Front-24mm Rear-22mmFront Mount Intercooler w/factory water sprayer (not the technical term!)Brakes: Brembo 4piston in front, Brembo 2piston in rearWheels/Tires: 17x8 Enkei w/235/45R17 tires (unsure of brand)Curb Weight: 3263lbs 60/40 weight distributionMileage: 18mpg city, 26mpg highway (if you can manage to keep your foot out of it! Hehe)
AWD, only available as a 5spd, four doors and it's gonna WHOOP YO ARSE! mine too...
What else would you like to know?
