evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Apr 21, 2008 7:03 am
I don't suggest alcohol in the gas, if you feel moisture is an issue you can buy fuel system dryer for a few bucks and it's got instructions, but sounds like your problem is the CHTS, which looks like an injector connector and is located on the front lower portion of your thermostat housing, make sure it's plugged in and that the contacts aren't all corroded, could be a bad sensor but most often it's a commector problem
