I have checked for a parasitic draw and came up normal. Maybe I need to check it during the rain?
246k 96 I30
I paid $600.00 for it. It just looked like a lot of connectors to take off for a 20 minute job. Maybe I am just letting the FSM diagrams scare me. Can I ask what year your I30/Max is?skyline084 wrote:So you're car is worth under 400 bucks?
eye30Chris wrote:The plastic shields were a little loose but in place overall. I tightened them up. I double checked the battery and alt and came up with 12.73v on battery and a steady 14.2 on the alt.(also tested 14.2v with defrost and headlights on) One thing I noticed was the alt would tap out about 14.35v when I revved the engine.(should I see more of a rise) I also checked for drop out on the B+ and came up with .031v. I wanted to also check the alt ground but I am at a loss for where to locate the alt ground. The Battery ground looks very clean and almost new. The battery is 4 months old.
loystock wrote:BTW, the symptoms you are seeing is a classic case of a failing alternator, in your case only when it rains.
