tvmendoza »
https://forums.nicoclub.com/tvmendoza-u28858.html
Sun Oct 16, 2005 7:16 pm
Ok here is what i did? Please correct me if i did womething wrong. I use as a reference the post that answered Structure like a year ago. I put my HI-Trtl and LO-Thrtl at -27%. Then on my DEC.-Air i did this:"when the car is completely cool start it up. have the safc mointoring throttle %, air flow, and rpms. have the engine at 1000rpms and write down the air flow. then have the engine at 2000rpms and write down the throttle % and air flow.now go to the dec. air settings. the THR setting is the throttle % you documented at 2000rpms. the NE1 setting is the air flow you had at 1000rpms. the NE2 setting is the air flow you had at 2000rpms. this will get you very close to the settings you need. may not be perfect but very close. this will allow you to run an atmospheric bov without stumbling between gears" From structure answer
Is that ok? ALsol i did it instead of 1000 i did it like at 1100 since the car did not went down.I started it and the car is shaking realllyu bad i did not use it since it still does not have the headlights and is dark What should i do i have to bring it to the body shop tomorrow at 9 so they can put the bumper and the headlights
Thanks
