robbie2883 »
https://forums.nicoclub.com/robbie2883-u41470.html
Sat Oct 17, 2009 5:59 pm
so, not sure why or what as i've never seen a belt and pulley do this. long story short someone else put the timing belt on the motor and i went to pull it all apart and double check it all today. now keep in mind this motor has maybe 2-3000 miles on it total since it was rebuilt. first things first, they put the crank timing gear on backwards, so there was no way to know for sure the crank was lined up properly. although it was on the 9th tooth which is where the marked tooth is as well. flipped it around and that's fixed. supposedly the belt, spring, idler and tensioner are all new. while the pulley's look like they could be new, the spring is deff not new. now for the fun part, the belt looks BAD on the outside but the teeth look good, and the idler pulley has some of the blue off the belt one it's surface...it's hardened on there like it was cooked on. both pulleys have grooves i can feel with my fingernail and the tensioner has a couple specs of metal shavings. there are absolutely no other signs of metal shavings anywhere....not in the oil or anywhere else around the motor other then just the tensioner pulley. the one other thing i did notice is he put the conical washer on backwards on the tensioner pulley, but could that have really caused the damage? maybe the pulley could wobble b/c the washer was backwards?
needless to say i am going to just buy all new parts even though i was NOT wanting to spend that money. just sharing to see if anyone had any insight as to how this could have happened? the coating on the idler pulley stumps me the most since it's only on that pulley.
