Godzillarb26dett wrote:J-SPEC TUNER...what are u planing for your SR swap....if you are leaving the stock internals and not adding cam....etc.....u should step up to a s-14 blk top with the vvt (variable valve timing) usually over here the engine can be bout for a few more hundred dollars.
My s13 SR20 will make more HP than the s14 SR20 for about the same amount of money. The VVT gets in the way when you do a turbo upgrade and the highport heads on the S13 are better also. I alreay have a full exaust (including turbo manifold, downpipe, high flow cat, and cat-back exaust), a S15 T28 BB turbo, and i am waiting to buy a Intercooler, Greddy profect B boost controller, 550cc injectors and Apexi SAFC for when i get back from college. Im guessing this set up should get me anywhere from 250-295 at the wheels depending on how well i can tune it. Alot of my mods wont give me any horsepower (engine mounts, KOYO radiatior, electric fans, etc), but i like to keep a engine running safely
