WDRacing wrote:Devious, you're smart SOB, I'm glad your here to answer questions like this and give out all the info you have been lately. Just wanted to extend some gratitude.
WD
Oh, well, hey thanks! Glad I can help.
There is potential for full nissan distributor support soon, the whole problem with this currently is that the nissan CAS is such a high resolution wheel. The amount of processing power required to accurately read say, a 1 degree signal (360 slit) at 6000-8000+ rpm is relatively intense. The current ms systems are based on a single (yet powerful) processor, but this particular type of task (high res wheel decoding) is a bit steep.
So, that is one of the purposes of these up and coming external boards that work on the CAN bus. They will have seperate distributed processors to handle these things.
The main MS units that you see available now will be part of this system. The MS2 is capable of using what is called CAN bus (you will hear this a lot in the automotive world these days), simply put, this is a system for multiple processors to "talk". All of the new external units such as the routerboard (used for sequential inj, and COP) and the GPIO (general purpose i/o) will be "chained" on this CAN bus and they will all talk to each other.
This makes it very easy to put together an MS system as money permits, you buy the main MS unit first (MS2 w/ v.3 board), and then have option to upgrade to the router or gpio board (and maybe more stuff too) in the future. In other words, if you are thinking about MS and not sure if you should get into it now, or wait, no worries. Buy the base MS2/v3 unit, you wont miss out on anything, you will have a head start.
Ok, and another thing about ignition control. You can swap a mitsubishi or mazda CAS disk into the nissan distributor (which is made by mitsu). Some of these disk's dont have quite the high resolution of the nissan part, and are easier to interface to MS with current options.
You can also use Edis, like I did a while back, a hacked distributor and some sort of HEI, and a few other methods as well.
I have the nissan CAS simulated electronically on my bench, once I pick up a gpio and a routerboard I will see what I can do to interface it.
I forgot a few things I wanted to say, but there you go.
