Any adjustments to make it fit or just a drop-in?How much is a battery like that go for?pdqwrx wrote:I havn't taken any picyures of it in the car yet, but I fit this Stinger battery (THe 1700) in the stock location with no problems and it kicks both the Optima red and yellow tops butts.
http://www.stingerelectronics....2.asp
What battery would you recommend?Q45tech wrote:If you study the specifications of the 1700 you will see it is rated at 72 Ampere Hours. it kicks both the Optima red and yellow tops butts. say what?
The Q45 has a requirement for an 80 ampere hour battery
BE CAREFUL TO READ THE FOOTNOTES ON HOW EACH MANUFACTURER SPECIFIES AMPERE HOURS. some use 10.0 and some use 10.5 volts [optima] as the cut off
Most don't specifiy Ampere Hours they confuse you with CCA cold cranking amperes or worst RC reserve capacity
Belts/hoses and such do get checked , but I'm not aware of a way to check the tensioner pulley(s).Q45tech wrote:How is it possible to loose an alternator belt when you examine them at every oil change?
Me neither.GQ Jay wrote:yah, i didn't see 80 A-Hr from readily avail info--that is potent for a group 24. Is that independent measured or unsubstantiated mfg. claim?
How about a pic pleaseGQ Jay wrote:So i went to pepboys and got the red 34/78. brought it home (like they are gonna touch the Q....) popped it on the float charger, used the supplied lid to bring it up to group 24 height. Satisfied for now.
No, there is a new service mentioned in General Chat.GQ Jay wrote:sorry for not posting to the gallery, seems to not be accepting uploads right now....
When you host with imageshack, just copy the very last link for the pic and then when you bring it here, paste it between the following:maxnix wrote:ImageShack links just go to boxes with red X for me.
