evaporator replacement, dashboard removal
KarolGT
Car: 2010 Infiniti M37 S
Hi
I need to replace evaporator, any tips? Do I need to remove dashboard?
If yes, if there any instruction how to do this?
I did not find anything on YT.
Thanks in advance
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yes, the dashpad has to come off as well as the steering crossmember. You can find the R&I instructions here on page ATC-119, and the exploded drawing for disassembling the HVAC Unit on ATC-122...
https://www.nicoclub.com/service-manual ... %2FATC.pdf
...and the exploded drawing for the instrument panel here on IP-11:
https://www.nicoclub.com/service-manual ... 0%2FIP.pdf
It's a BIG job.
KarolGT
Thank you VStar650CL
VStar650CL
Technical Expert
:dblthumb:
