qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sat Apr 19, 2008 2:06 pm
Ok, what started out to be a simple spray foam evaporator cleaning got complicated thanks to Q45techs post so.......
Just completed a manual cleaning of evaporator-removed glove box, darlington turd, and blower motor...and found about 1/3 of total area of evaporator face blanketed with a black matted mess {looked like clothes dryer lint screen after washing black towels, only greasy}.
I used a toothbrush, chop stick, and mini-shark vacuum to remove as much as I could get to{about 10% of evaporator face was impossible to get to due to obstructions from freon lines, expansion valve temp sender,etc. I then reinstalled blower motor and darlington turd and injected entire can of the power foam in to evap. case thru a small hole in case. A small amount of foam found its way out of several crevices in blower case and evap. case
Reinstalled glovebox and lower dash trim, stuck the taylor dig. thermo. in center vent and went for a small drive.... results are positive as I saw 46.1F vent temp with fan on HIGH, recirculate on and before procedure I could not get below 51.2F under same settings and outside temps
I highly recommend fellow Q owners to spend the 1 hour to clean their evaporator, as I was shocked at the amount of restriction across evap. face and happy to get 5 degree cooler air {airflow seems stronger also}
