EVAP removal
JJ240
Car: 95 white 240
What do I need to do with the lines running from the EVAP canister after I remove it? The line that runs straight out the bottom into the fender I assume is a vent so it can be left open. But what about the line that runs to the back of the car? And the vacuum lines that run to under the throttle body? Yes I have already removed it so dont tell me just to leave it on :D
maxpower
Car: WRX
That pressure sensor that's behind the canister went bad last week. I didn't think it made sense to spend 100 dollars on a sensor that doesn't effect engine performance in anyway (it's used to report back to ecu). So I ripped the bastard out and used screws to seals up the hoses.
The only downside is that the ecm is reporting an error now (obd2)
240_Keyy
Car: '90 240 Fastback
I removed mine. All you have to do is plug the fuel line that goes into it and then cap off the fitting on the TB.
JJ240
Car: 95 white 240
cool thx guys
