Evap Codes
Patrick82
Car: 2001 Nissan Pathfinder
Hello, I have a 2001 Pathfinder with high milage 235,000 I just replaced the alternator (not fun). My heck engine light has been coming on quite frequently and they are all evap codes with the exception of 1 and that is an 02 sensor. The codes are P0441-Evap not functioning correctly, P0455-Evap leak, P0140- O2 sensor bank 2, and P1491-Vacuum Cut Valve Bypass Valve-. I guess my question is where do i start? and if I need to get this fix how costly will it be? I have get my inspection done and I live in New York with emmsions tests. Thanks!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Replace the gas cap with an OEM sensor to begin with, it may solve your EVAP code.
P0140 is a rear oxygen sensor high voltage malfunction and is not critical to engine operation. Replace it with this Bosch OE-type O2 sensor from Advance Auto Parts - you can purchase it for $52.99 before tax if you order online using discount code VISA and pick-up in store. Bosch is the manufacturer for the original O2 sensor. You will require a 22mm or 7/8" oxygen sensor socket for replacement.
See this post for possible causes regarding P1491.
Azndjay
Car: 2001 nissan pathfinder
2008 Acura TL type S
2003 Acura RSX
i had the same codes as you ,except mines end up being fuel pressure reg and fuel damper.
evap cannister is easy to replace if you go down that route , one word of warning . You might want to use a impact or cordless impact wrench for the bolts holding the canisters. Why? so the bolts don't break . some do, some dont something to think about while down there
Patrick82
Thanks guys just replaced the Vacuum Cut Valve Bypass Valve lets see how it goes. See how many more codes I can get to pop up. Ahh
Patrick82
Now I'm getting a p0446 code anybody know where to go from here?
Towncivilian
The FSM does not list P0446, are you certain that's the correct code?
Patrick82
Yep that's why I'm confused. The generic code is evaporating control systems.
Towncivilian
Try replacing your gas cap with a new OEM one.
Patrick82
Tried that too. Its going to the garage tomorrow!
