evap canister & vent control valve replacement
InfinitIly_fInnI
Car: 2014 Nissan NV200
does anyone have diy info on replacing these parts? as always everyone has been helpful and it's highly appreciated. thank you
maxhopper
Car: 02 Maxima SE 6spd
For what year and model?
InfinitIly_fInnI
2002 i35. My bad
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Are you sure you need to replace the canister and vent control valve? Do you have specific trouble code? Trouble codes associated with those components are sometimes jut due to loose connections/fittings or cracked tubes. Jack up the car and make a thorough inspection of tubings and fittings. If you have to disconnect tubings, make sure you mark them as it can get complicated if you make a mistake.
EVAP related CELIt could even be caused by a defective or ill-fitting gas cap or corrosion on the area.
For reference, look for trouble codes P04xx in the link below:
http://www.nicoclub.com/FSM/i35/2002/ec.pdf
InfinitIly_fInnI
loystock & maxhopper thank you guys...you 2 have always been very helpful and highly knowledgeable....thanks again
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
It's our pleasure to help. But please note that all moderators here are volunteers. We work on time available basis and our first priority is our regular job.I've been on the road (worldwide) since December and only pop-in whenever I could. I'll be on the road again next week.
