Evap canister location on 2021 rogue SV awd
mjmarquez
Car: 2021 Nissan Rogue
Does anyone know where the evap canister is located on a 21 Rogue SV awd non turbo model? I’ve done several searches to no avail.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's covered up by the passenger side under-cover, just forward of the fuel tank. Same location for both the KR and PR engines.
mjmarquez
Thank you. I’m chasing a p0456 code. Thought I’d try the purge valve on the canister and go from there. Any suggestions as far as where else to look for this problem? This is my first Nissan. Any help would be appreciated!
VStar650CL
Technical Expert
The prime suspect on any late model Nissan (besides the filler) is the grommet for the evap vent. Here's your plumbing, the leak can be anyplace in red. Don't let the diagram confuse you, the EVV and evap pressure sensor are both in the canister, not external as the diagram implies:
mjmarquez
Thank you. This information is most helpful!
VStar650CL
Technical Expert
:dblthumb:
mjmarquez
After using a smoke machine, I discovered that the evap canister itself had a crack in it and thus was causing it to throw the P0456 code. I replaced the canister, reset the dtc code and within two days the permanent dtc code cleared itself. This forum was most helpful in helping me correct this issue.
VStar650CL
Technical Expert
Good work!
:dblthumb:
mjmarquez
Thank you VStar650CL. The diagram and information you provided helped immensely!
Return to “Rogue Forum”
