IvoryJ30t wrote:hey, maybe evans is good stuff. i just dont like BS marketing tactics like this-
"Evans NPG Coolant will transfer 27.5% more heat energy than water in your race engine, due to NPG's molar heat of vaporization and high saturation temperature."
maybe im a little off on my physics/chemistry, but how would the heat of vaporization have anything to do with a coolant that never boils?
The vapor saturation point can dictate the presence of nucleate boiling within the molecules lining the coolant passage walls (which is where the majority of thermal transfer takes place). This takes place as a result of the subcooled fluid being of a varying temp, which absorbs the gaseous bubbling thus creating a quench effect along the walls. So such factors like temp, saturation temp, interfacial heat transfer coefficient, latent heat, vapor void fraction, and down to the number and diameter of the gaseous bubbles. This can dictate small differences in thermodynamic properties under high stress (heat/pressure) situations. It is evident in the small graph below.
You'll find that a large part of the world uses Propylene Glycol based coolant as standard due to the environmental hazards of EG.
http://www.lyondell.com/html/p...shtml
More than you wanted to know about PG.
PG has also been ran in racing for quite a while now... it yeilds greater efficiency in extracting heat from the head. GM has proven this, as has plenty of others like BMW, Porsche, Audi, VW, and a number of other European car manufacturers.
Me and Fred have been researching PG for the past month or so, and if you'd like I can give you some inclination as to what we have found but the links really give you most of the answers.
Graph:
More Links.
http://www.lyondell.com/html/p...ation/ ... /p...shtml
Equation Links to Thermal Mathhttp://wins.engr.wisc.edu/teac....html
This is about the boundry of my abilities right now
