jgruiz wrote:Ok people; how far should I be able to go in "EV" mode if there is a full charge on the "big" battery. No wind, flat ground and no stops?
Really depends on your driving style. I can usually get about 1.5 miles if I get up to speed and glide only using the Electric Motors. By glide I mean I am not using the battery or the Engine, I am just keeping the car from regen braking(power meter is at 0). The startup is the killer. That will zap most of the battery away maintaining speed is much easier. Try it out and you will see that the battery is not good for more than 1/2 mile if you are trying to maintain 42mph with the battery.
