european vs japanize
eurosx
Car: cars
Hey ya'll, I was just wondering if there were any differences between the european CA and the japanize version?
themadscientist
well euro is 200SX right? Japan is 180SX or Silvia.Does your car have right hand drive? Japan does.
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
no the euro ca18det is still the 1.8, or so i thought, the 200sx is the sr20 we get in america, no turbo tho!!, and the silvia (240sx here runs a KA24de, n/a)
eurosx
Car: cars
my bad, I didn't finish what I ment. I am asking about the motors. Are there any differences in the production lines: same cams, same turbo specs? Anything like that.
eurosx
Car: cars
or in other words, which is better to import for transplant into a 240 in the states or is there a difference?
rtsol
the euro spec has a 4 port head/manifold right? instead of the eight butterflies. im probably wrong as usual.
nlzmo400r
mmm, im not too sure but i could look it up and get back to u, im pretty sure (99% to ball park it) thta the jdm and euro specs are identical
themadscientist
nlzmo400r wrote:no the euro ca18det is still the 1.8, or so i thought, the 200sx is the sr20 we get in america, no turbo tho!!, and the silvia (240sx here runs a KA24de, n/a)
No in europe it is called a 200SX, even the Ca ones are called that. I know the 200SX you mean, that's a sunny in Japan. Don't you love the name shiuffling the Japanese do to confuse us?:mad:
Nathan
I thought the intake manifold was different on the european spec CA as well, and also, CAN you import the european one's? I have never seen an importer for the European CA's, you might be able to get a newer (in years) engine since they were made until 1993?? there? I think I heard somewhere they were...or maybe it was 1994, anyway point is that they were still put in 200sx's until then. You can always get a rebuilt one from http://www.norrisdesigns.com I wish I could have one of those! but they arent the cheapest.
Doogz
Car: '89 240sx coupe
rtsol wrote:the euro spec has a 4 port head/manifold right? instead of the eight butterflies. im probably wrong as usual.
You aren't wrong rtsol. Right on the money actually and also i think there may be a difference in the ecu's but im not 100% sure on that one.
eurosx
Car: cars
Nathan wrote:you might be able to get a newer (in years) engine since they were made until 1993?? there? I think I heard somewhere they were...or maybe it was 1994, anyway point is that they were still put in 200sx's until then.
The british never switched to the SR20 like Japan, therefore the CA was used through the entire S13 line.
eurosx
Car: cars
so which is better? the multi-port head or the butterfly?
Doogz
No one is really sure which intake design is better (as far as i know anyway) Alot of ppl in the US rip the butterflies out, but i have also heard that alot of ppl in japan prefer to leave them in. I think the theory behind the butterflies is to help with intake air velocity at low rpms and then they open up at higher rpms to allow better flow. To me it just seems like something else to go wrong and when i get around to it eventually...i'll probly gut em.
themadscientist
well if you rip them out you will have to TIG weld the holes for the butterfly shaft and it will be sluggish down low. They open up when the engine needs it so I would leave them in.
JDM_1990_S13
they help in the intake velocity at low rpms and will help with gas mileage etc...
paul_s13
eurosx wrote:so which is better? the multi-port head or the butterfly?
I've owned both and I would say the UK 4 port is better.
float_6969
Don't you think it just goes to show how advanced the CA motor really was. Almost 15yrs ago nissan designed that motor with a variable intake. Now, the VQ series motor has the EXACT same technology. Longer intake path down low for high velocity air flow for better torque, air/fuel mixture, and gas mileage. In the upper revs, the butterfly opens to allow a shorter intake path for increased flow for higher top end performance. D A M N I love this motor!
Nathan
And that's why it's the engine of choice for everyone here on the CA forum!! Those poor SR guys dont know what their missing out on...
rogue
KS_Honda_Killer wrote:Don't you think it just goes to show how advanced the CA motor really was. Almost 15yrs ago nissan designed that motor with a variable intake. Now, the VQ series motor has the EXACT same technology. Longer intake path down low for high velocity air flow for better torque, air/fuel mixture, and gas mileage. In the upper revs, the butterfly opens to allow a shorter intake path for increased flow for higher top end performance. D A M N I love this motor!
yes, the variable intake was good, but the corolla GTS was using it back in 86 with the TVIS sytem.
Current day 94+ Integra GSR also used this same system.
It gave good low end torque, then nice highend.
JDM_1990_S13
the following is a scan of an article in Sport Compact Car about variable intake runners etc.. 353kb zip file.
SCC Variable Intake Manifold Article
boost_boy
Quote »yes, the variable intake was good, but the corolla GTS was using it back in 86 with the TVIS sytem.[/quote] The CA18DET has been out since 1986 as well in the S12 sylvias and gazelles, so now we're talking 17 years which is well in-line with the 4AGE motors and that's why nissan and toyota still are the iconz in japan. Mitsubishi is the richer of them all and mazda, well mazda is like saturn "A different kind of company".
slw240sx
Car: 1990 Ca18det 240sx Hatch
Quote »well mazda is like saturn "A different kind of company".[/quote]
LOL!!
undertaker
Car: C33
On the subject of nissan variable intakes the early RB20 (R31 skyline) has a more complex system. Called NICS (induction control system) it uses completely separate long/short runners (not siamesed like the CA) and a 12 port head. It has red rocker covers so it looks a bit like a long CA. Early non-intercooled CA's has a completely different manifold with a central mount throttle body and smaller plenum chamber.
NeedCAforS13
Car: CA swapped S13 coupe
I think the ca18de pulsars used the NICS system...thats what it said on the intake mani if i remember it right...
Sean
boost_boy
Quote » think the ca18de pulsars used the NICS system...thats what it said on the intake mani if i remember it right...[/quote] The older CA16 and CA18's have the multiple runner set up with the funky ports on the head.
