you can order any side marker lights from any online store, and wire them in. it will require you to drill holes in your fender.apolodor wrote:Does anybody know where I can find European side marker light (yellow)?
Can I use the one designed for Nissan Qashqai? Are they compatible?
Thanks!
Car Side Marker Turn signal Lights bulbs lamps For Nissan X-trail Qashqai Dualisapolodor wrote:Does anybody know where I can find European side marker light (yellow)?
Thanks!
Wow.. they look fancy...Rogue One wrote:Car Side Marker Turn signal Lights bulbs lamps For Nissan X-trail Qashqai Dualis
Not OEM, but wouldn't look to bad.
http://www.ebay.com/itm/Car-Side-Marker ... 27&vxp=mtr
http://www.ebay.com/itm/Side-Marker-Fen ... 33&vxp=mtr
? HUH ?apolodor wrote:I was asking about the signal lights from the back of the car.
Can you please claify? What lights are you referring to?apolodor wrote:Wow.. they look fancy...Rogue One wrote:Car Side Marker Turn signal Lights bulbs lamps For Nissan X-trail Qashqai Dualis
It's a two piece set that I've only found the large half on eBay: http://www.ebay.com/itm/2012-Nissan-Qas ... 51a09a4febapolodor wrote:I was referring to the back tail light not the side light.
Qashqai: http://4.bp.blogspot.com/-lBzwLgE9aas/T ... qai-24.JPG
Rogue: http://www.nissaninthenews.com/wp-conte ... -image.jpg
That's only part of the hurdles you face:apolodor wrote:I will use the Rogue in Europe so I have to comply with local laws which require to have yellow as turn signal lights .
That's why I asked if I can replace Rogue's back lights with the ones used by (a) Qashqai.
either i totally missed your initial quesiton, or you went back and rephrased your first post. anyhooapolodor wrote:I will use the Rogue in Europe so I have to comply with local laws which require to have yellow as turn signal lights .
I love the tail light for the Nissan Qashqai. Those are sexyRogue One wrote:
i dont mind drilling metal either, i just did for my spoiler. the problem is that the quarter panel wont accept a different shape tail light, given the shape its bend in for the stock tail light.Leo2005 wrote:I don't see a problem of drilling a metal when you want to install something. Dip the hole around in paint, get the wires throw and cover up with your emblem on top of it (with 3m double tape under it). About 7 months ago I have installed dual color nissan emblem on the trunk and have no problems at all:
[youtube]http://www.youtube.com/watch?v=Pd2CtQjw ... uy4AI48ITQ[/youtube]
I don't think that local authorities would accept that...ImStricken wrote:no, the two taillights are totally different. unfortunately your out of luck UNLESS you somehow stick orange bulbs in there and they light up orange through the red lens.
GREAT IDEA SQASH!Qashqai wrote:I think I found a solution for your problem...
All Rogues have two circular, TRANSPARENT reverse lights on the back. Replace their white bulb with amber/yellow bulb. Rewire the whole assembly, so that when you give signal, the circular signal lights (previous reverse lights) will blink. The authorities require yellow signal light, but they cannot specify location or size right? (as long as it is extremely small or not close to the sides)
In this picture you can see the yellow circular turn signals and a proposed rear light add on to the bumper
http://www.flickr.com/photos/60569238@N03/7901253108/
- The old red signal lamps will act same with the rear red lights.
- You will add external white lamp on your bumper (I don't know how) for your new reverse lights...
Done!
