Euro Zenki Headlights High Beam
enkei2k
hey, does anybody have a step by step install as to how to get these to work, what parts are needed?
Is a H4->H3 converter harness the best/easiest way?
All i know is that re-wiring is needed since the high beam uses H3 vs H4 for USDM and low beam. Thanks for the help.
r3v_v3ng3
Car: 91 fastback ka-t
thats probably the best and easiest way to do it. now if you want it cheaper just go to a junkyard and find a car that has a h3 and cut it. put it in your pocket and go home and cut off your old one and splice/solder it with your old connector
