With enough Nitrous it will damage everything. In small enough amounts as long as there is the right amount of fuel then its just like using normal air.Ginsu wrote:I just found this. I guess some industrial diesel engines already have this type of thing, but for cold starts only. But then why doesn't nitrous damage the rings & seals?
http://www.tpub.com/content/co...9.htm
Diesels mainly use glow plugs nowadays. You have to remember, diesel engines use a different kind of Internal Combustion. Instead of electrical ignition like normal engines do with spark plugs, diesels use compression ignition. They compress the air/fuel mixture to the point of detenation.Ginsu wrote:I just found this. I guess some industrial diesel engines already have this type of thing, but for cold starts only. But then why doesn't nitrous damage the rings & seals?
Uh... not quite. Nitrous oxide is injected as an oxidizing agent and boost the amount of oxygen available - not to "cool' the air. In essence, nitrous oxide increases the % of oxygen in the air.Red Devil wrote:Nitrous functions to increase the amount of air to burn in combustion. When released into the combustion chamber it cools he air, increasing density.
If the chips software is crap, yes. As an general description of chipping, wrong.Ginsu wrote:chipping your engine injects more fuel than is appropriate
My first car was a 1946 Willys Jeep that had a lot of trouble starting in old weather. I used to use a can of ether to help.Ginsu wrote:Hmmm... what if you rigged a setup where at the push of a button you could inject ether directly into your air intake?
