96Qowner wrote:Ethanol reacts with the potting compound in the Q45 injectors. It swells and pulls the windings apart, radically altering resistance and causing the injector to fail. Texasoil soaked a few used ones in ethanol blend and watched what happened to 'em - tested 'em - resistance went sky high after a couple days.
You can't run ethanol in a G50.
Bad news. We have no choice here in Phoenix.
How about 2005 F50? Are the injectors in newer VK45s updated to tolerate the ethanol blends that are fast becoming the only fuel available in many areas?
Interesting story:My '94 Q45t had one injector after another go out, two in warranty and two after. The car was well out of warranty with the last bad injector. I called Infiniti Customer Service and pitched a fit, telling them that our other cheap family car had NO injectors fail after 70,000 miles, and that I had friends with cheap cars that didn't need ANY injectors even at 100 and 150k, that I expected better from my $58k luxury car. They told me that there are new updated injectors designed to cope with ethanol that wouldn't poop out on me, and that I probably already had at least 3 of them from the previous replacements. I stuck to my guns and demanded a full set of all 8 new injectors. They finally agreed to replace all 8 if I paid for labor, which I did. After that, I never had an injector problem. I'm wondering if the G50/VH45 updated injectors were in fact designed to tolerate ethanol blends. I traded it with around 40k miles on the new injectors, and they were fine after all those miles.
Comments on both situations?
