All the above "tests" are irrelevent, as in the first test pure ethanol was used, and in the second test you mentioned, 20% ethanol mixture was used. The ethanol content in the fuel we are so afraid of is 10% MAXIMUM by law {which Infiniti says is OK to use as per my owners manual}96Qowner wrote:And texasoil put a Q45 injector into ethanol and watched it swell and break the windings in a matter of a day or two.
The real issue is WHY are the windings failing? I suspect the ETHANOL in gasoline today is attacking the potting compound of the injector body, causing it to swell and pull the wires in two internally.That's the 'post mortem' I did on 3 'original' ones off my '94--all wentprogressively HI ohms in 3 months of ethanol in gas. The other 5 had been replaced by P.O. just B4 I bought it 4 yrs/50K miles ago and have different potting compound.
And this:
Re: swelling and resistance: I took a 20 ohm original injector (not too bad but out of tolerance and not going back in), and put it in a jar of 20% ethanol in gasoline. In one day it went from 20 to >2K, and in 2 days went to infinity (open) Q.E.D. as they used to put in my Calculus books-the proof is complete. I do not know if later potting compounds are similarly damaged by ethanol--I suspect not since MTBE was in wide use by mid 90's. I did not see any fuel line deterioration though-would not expect it. Other plastic parts? case-by-case. fuel pump?looks like nylon or delrin--not likely to be affected.
zerothread?id=215772
Dunno. I haven't heard of 96s having injector troubles, though.
Yup, before long, it will be everywhere.There won't be any choice.Doncha just love how government "looks out for us"?AlabamaDan wrote:
Found the same thing at pumps yesterday. Drove around till we found one that didn't have the sign. Looks like bad times are coming for gas quality.
Really? I run Wawa gas in my Q out here. Nothing less than 92. I haven't had any fuel issues.oldmako wrote:It would be nice to know which refiners consistently use it and to what concentration. In other words, one could regularly purchase the best (least contaminated) gas available. I run WAWA gas in my boat for a variety of reasons, but I steer clear of it for the Q.
THANKS FOR THE LINK....IM IN KANSAS AND WORK IN MISSOURI AND IF IM READING THE LINK RIGHT THOSE TWO STATES ARENT REQUIRED TO PUT STICKERS ON THE PUMP??? I WAS DISCUSSING THIS WITH ANOTHER AT WORK AND SUGGESTED THAT SOME ISO HEET WAS GOOD FOR EVERY TANK???Q451990 wrote:Here's a web site that tells about pump labeling requirements by state. Who knows how well these regulations are enforced.
http://www.ethanolrfa.org/policy/actions/state/
