CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Fri Jun 13, 2003 7:49 am
my virtual engine, with the parts i have collected:
Turbo Piston engine BSFC .60Fuel Presure 43.5psi4x550cc injectors4x370cc injectors (secondaries)15% RWD Drivetrain loss
493 HP419 WHP
thats what the calculator says my fuel system can support and estimated power out put.
it also goes onto say my recommended fuel pump presure.. cool
i require a minimum of a 186lph fuel pump to run 25psi boost... well a 255lph pump is a good safety margin, and i should be running about 84psi fuel presure.
cool calculator, kinda matches what i am aiming for,
