dholly wrote:Forte - Like the RS*R 350z downsprings @ 0.6" drop, it sounds like these springs offer a moderate, rather than significant, drop option for G35 coupes. I would like to compare spring rates and design of the two. Do you know if the Espilir downsprings are progressive, linear, or a combination, i.e., front/progressive and rear/linear? If you have them, please post the f/r spring rates - for progressive, initial/final would be very helpful. Thanks alot.
rydwhite wrote:The lowering looks great Forte. Well, the whole car looks great, the lowering just keeps adding to it. I wasn't sure if you were going to be able to make it up on that dyno though, but you did and it was very close. I think a little something might have hit when pulling up there though.
GeeThreeFive wrote:Have you put pics of your car in members rides yet?Did you just get the set of pulleys or just the one?
dholly wrote:There is a blue Active Super Down spring for the sedan (p/n ESA060) with a 40mm/40mm F/R drop and a red Active GT spring for the G35 coupe (p/n ESG059) with a 10mm/10mm drop.
They sure look progressive to me, particularly the ASD for sedan, but I can't find the actual spring rates for either of them! I would like to calculate their front to rear spring rate balance vs. OEM balance. Some of these aftermarket springs transfer as much as 30% more spring balance (roll stiffness) to the front than OEM. That creates a huge amount of additional understeer to contend with. Adjustable sways are a MUST have to dial it out. Curious if you have noticed increased understeer at the limit with these AGT springs?
Also, according to this site: http://www.mackinindustries.co....html, there appears to be a new ASD application for 350z on the way.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
