ESPELIR SPRINGS for G50 and Y33.. Group buy, $380 shipped!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
BUMP!
redmanfx
Car: 92 Q45a
Interested but want a guinee pig to get them first. O,o Still riding with my Cali customs!
lpreston
Car: 97 Q45
I'm considering these (Y33). In regards to lowering, will any other components have to be replaced to keep an alignment on the car? Am looking at the Bilstein units to replace the stock ones when the lowering is done.
Thanks...Lewis
elwesso
2007 BMW M Coupe
redmanfx wrote:Interested but want a guinee pig to get them first. O,o Still riding with my Cali customs!
Read on sir, ive already sold them to one person and he said he LOVED them..
lpreston wrote:I'm considering these (Y33). In regards to lowering, will any other components have to be replaced to keep an alignment on the car? Am looking at the Bilstein units to replace the stock ones when the lowering is done.
Thanks...Lewis
You can get a pretty decent alignment with these springs. Rear is the only issue and you can get control arms if you dont want to run more than -2* camber, which isnt that much IMHO (not enough to cause unusual tire wear)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
lpreston wrote: Am looking at the Bilstein units to replace the stock ones when the lowering is done.
Really? Which?
elwesso wrote:You can get a pretty decent alignment with these springs. Rear is the only issue and you can get control arms if you dont want to run more than -2* camber, which isnt that much IMHO (not enough to cause unusual tire wear)
Well, with my Eibachs on the FGY33, -2.5° which did not help Direzza DZ101. I will be going to SPL RUCA as soon as they receive the revised clamping nut.
audiovisiony33
Car: 1997 Infiniti Q45
I used to have Eibach's on my 97 Q. Eibach is a great springs but it didn't sit as low as I wanted and didn't lowered that much at all. Looked almost stock comparing to other sedan's.
Now I have Espelir ESN149 with KYB SR and it sit's 3/4 of an inch lower than the Eibach's. Now the Q looks lowered with balanced clean drop.
In my overall experience with Espelir ride and responsive is smoother than the Eibach's due to being a linear springs rather than the progressive type springs. Plus I didn't have any alignment issues comparing to the previous Eibach set up. I'm very picky about the ride quality and I highly recommend the Espelir springs.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
audiovisiony33 wrote:I used to have Eibach's on my 97 Q. Eibach is a great springs but it didn't sit as low as I wanted and didn't lowered that much at all. Looked almost stock comparing to other sedan's.
Exactly why I love them, along with increased spring rate. With broken in KYB SR Specails, great ride and no fear of sloped entryways or speed bumps.
Still have to buy RUCA to restore rear camber to OEM specification. Now -2.5°
audiovisiony33
maxnix wrote:With no data, no one knows exactly what they are buying.
Tough sell.
I just got an e-mail from ESPELIR on the spring data you were looking for.What do you think now?
Cima/FGY33ESN-149 F/ Outside radius 167/208mm / Rate 3.2kESN-149 R/ Outside radius 116/132mm / Rate 2.8k
President/G50/Q45ESN-156 F/ Outside radius 94/123mm / Rate 4.6kESN-156 R/ Outside radius 115/129mm / Rate 4.2k
96Qowner
Car: 1996 Q45
Stock rate is 2.63Kg/mm and 2.20Kg/mm for the G50, so that's about twice as stiff?
zerothread?id=279168
Q45tech
Q45:257 lb/in front and 234 lb.in rear is 52.3%/ 47.7% roll stiffness ratio but then again kg/mm should have 2 decimal places not one to show 1 lb resolution.
Shocks are speced at a standard case/fluid temperature since the viscosity changes significantly with temperature so what works/lasts ok cold will feel worn out and weak in extreme Summer or rapid cycling conditions. Why real shocks have external fluid tanks and radiators to minimize temp rise.
When you substitute springs the front sway bar will contribute less [% gain] and springs more in a roll. So the built in understeer will be less so a rear sway will be less effective also.
All about front rear roll stiffness ratios.
elwesso
2007 BMW M Coupe
Just updating, theres only like 5 sets left of G50 springs.
SpartanAir
Car: 1992 Nissan President Sovereign, 1990 Nissan Pathfinder XE
Hi Wes,Sent you an email but just wondering; any sets of springs left?
Thanks!Brendan
elwesso
2007 BMW M Coupe
no sir...
