holy shiznit you actually like something i did...now i gotta be even more of an a@@rjdmmfl1 wrote:Vonvivo, thank you for that website! I will be purchasing both the laser interceptor and veil... that should make me damn near invisible without triggering jam codes!
vonvivo, I think you pride yourself on being an a$$... you know you do... this isn't something that happens by accident... but even that doesn't stop you from offering positive advice when you want to, and I respect that... some folks are just negative about everything, and that helps no one!vonivo wrote:
thanks... good infoshortys408 wrote:when your laser goes off, slow down until you are at the speed limit than turn off your jammer. You are less likely to get pulled over that way because they will get your speed and no jam code.
