spank044 »
https://forums.nicoclub.com/spank044-u40173.html
Sun Jun 14, 2009 9:22 am
I have had 2 spec clutches in my kA-t. The first one was warped and only made contact with the outter 3/4" of disc. Now my replacement is correct and grabs great when I launch. I launch at 6200 rpm, with about 10 lbs. of boost, a single piece driveshaft, welded diff, and a pair of 275 MT Steet Radials. I have not had any problems with the new disc yet, but with any mass produced item there is always gonna be a few that fail.
I am a little confused about your problem still, in the first post you said sheared teeth on the pressure plate, third post was damaged input shaft splines, and fourth post was pressure plate failure. What failed the pressure plate or disc?
Spline damage most generally occurs from hard shifting and hard launching.
What kind of torque do you have? Is it a stock engine? Is that the right clutch for your application? Do you have a solid or spring hub? All of this info makes the picture alot clearer for the rest of us.
