error p0130
nj1sh
Car: maxima 96
i get an error code p0130 something about o2 sensor. anyone familiar with it?
nj1sh
Car: maxima 96
I think I have to replace it... should i just replace the one i get the error or all of them?
nj1sh
Car: maxima 96
it says bank 1 sensor 1... how many o2 sensors does 4th gen have?
lightsout
Car: 00 Nismo Maxima SE
you need this link:
zerothread/57985
check out the How-To's.
Bank 1, Sensor 1 means; the front exhaust manifold and the 1st O2 sensor.
this O2 sensor is mounted in the exhaust manifold, and can easily be done yourself
nj1sh
Car: maxima 96
thanks for the reply, I would like to replace all the o2 sensors... how many does the 4th gen have?
nj1sh
Car: maxima 96
can someone please tell me which one is (bank 1 sensor 1) o2 sensor from this diagram i am duMb http://www.courtesyparts.com/A32_O2-sensors.html
lightsout
sorry it took so long to check back.
bank 1 sensor 1 is sku# 22690-0008 Front Driver Side O2 Sensor
the easiest to replace i believe!!
before you remove the O2 sensor douse it with PB Blaster, or WD40 to loosen the threads.
nj1sh
Car: maxima 96
thanks for specifying it ill try to buy it tomorrow and install it. You can't believe how bad the car drives
nj1sh
Car: maxima 96
is it a good idea to change both bank 1 sensors?
Dansmaxima
Car: 2001 Maxima SE, 95 Jimmy, 91 GMC Sierra
I don't listen to my own advice: don't fix it if it aint broke. Why don't you replace the one and see how it runs? You might need an oxygen sensor removal socket, I think 7/8" box wrench will work too, but you'll have to cut the connector. I also had to get an 18mm thread chaser which was worth the $8.
nj1sh
Car: maxima 96
I went to a local auto parts store and they wanted about $90 for the sensor. I also did some searching on google and found some cheap sensors from $20 from a company called "Replacement". These sensors come without connectors. I am not sure which one I need... The three or four wire sensor.
http://www.car-stuff.com/store...pp=50
Norwegian Dane
Car: 1997 Nissan Maxima GLE
I would probably stay away from the universal O2 sensors. They are too much trouble. Just get an OE fit sensor and life will be good.
lightsout
stay away from the universal 02 sensors...in my opinion. get the OEM replacement from Kragen or Pepboys. $90 isn't bad...they are usually over $100.just replace the one 02 sensor, and see what happens after that.
Dansmaxima
I've had almost everybody tell me also not to use universal O2 sensors. I got Bosch universal sensors which came with little nylon compression connectors. I think my sensors have teflon insulation and stainless steel wires. I've tried to solder these wires together in the past with bad results. I got universal sensors to save $$$$$$ they are much cheaper. My Maxima manual has various tests for voltage that can be done.
