.....and if you can't locate a burned out bulb check each of the sockets in the brake lamp assemblies. They tend to melt, especially if you replace burned out bulbs with non-OEM.beancooker wrote:I believe that you have a burned out brake light.
not saying much,as my local dealer does not even stock basic items like shim kits!Q45tech wrote:Sockets have to be the most common inventory item besides filters, belts, and spark plugs, brake pads and rotors.
