error message on cd changer on my g35
Jeffrey_1234
Car: Infiniti G35 coupe
Does any one know if there is a way of reseting the cd changer on a 2003 g35 coupe?
joe603
Car: 2014 Durango R/T
Welcome to NICO!
Search the site a bit and you'll find that you are not alone. The 03-04 G35's have a problem with the CD player/AC system. Basically, you need to replace the head deck, there is no way to reset it.
There is the option to send the unit off to an aftermarket shop that can fix 'em, or you can have the dealer replace it.
The problem is a faulty circuit board that the CD player and AC controller share. Luckily, you don't have a problem with the AC!
Check out these guys for a shop to fix the head deck: http://www.shortcircuitrepair.com/infiniti.htm
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
common problem... Good work Joe!
WhiteG35Bullet
Car: 03 G35 CoUpE 6Mt
I suggest replacing it with an aftermarket double din than tryin to repair... thats what i did and its kooler than that 03 model headunit
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
yup, do this
much better sound, and the perfect time to upgrade
Jeffrey_1234
Thanks for your suggestion, but if i change it to an after market radio will my factory navigation still work with it?
tollboothwilley
yes. you just wont have the functionality of the voice(not a big loss).
you will need a dash kit to upgrade in addition to the stereo.
