elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Aug 24, 2009 5:13 am
Paul, you are not helping at all... It doesnt surprise me that he didnt find anything by searching.
Anyway, to the original poster, like they said the coil packs are likely suspect. Used ones might be a gamble since theyre known to go bad on these cars, I might just get a new one and be prepared to revisit this in the future... The dealer will want to replace all 8, and thats the sure fire way to eliminate it for a long time. You could also try your luck at getting some used ones...
Get your new OEM parts from Infiniti of scottsdale, info is in my signature...
Any OBDII scanner is going to be accurate enough, it can do 95% of what the nissan consult can do (nissan scan tool)..
Also, you can get knock sensors on ebay for about half the price of OEM. All 90-01 infinit use the same one, part number 22060-300P0.. Average price on ebay is 60-70.. You will want to replace the harness too, theres a few threads floating around on removing the plenum on a 97 Q...
