rustfarmer »
https://forums.nicoclub.com/rustfarmer-u310212.html
Mon Apr 15, 2024 9:00 am
I am trying to clear an error code for very small leak in evap system and the reset procedure followed carefully doesn't work. Unit never goes into diagnostic mode (ie: SES light never starts blinking). I tried disconnecting the battery negative overnight and that did not work either. Car runs fine. I replaced the gas cap and also replaced most of the rubber hoses related to the evap system so I want to see if the problem is fixed. Must I find a scan tool to reset the codes?
