Since you just swapped in your 1st gear start TCU you don't need to concern yourself with the error message. Disconnect your TCU and plug it back in making sure the connector is in straight. We've seen a few members have problems with TCU's and ECU's when the connector is not seated properly. Both are tricky until you've done it correctly one time and figure out the technique.Haitian_King wrote:Page 42 of the AT section of the FSM states, (When reconnecting A/T control unit connectors, this is not a problem)
But Infininti does, and you can obtain that record by asking for it.Haitian_King wrote:I have absolutely no maintenance records besides the ones i've been keeping.
It should be bright pink like new. Do the white paper towel test and report back. The visual difference is indicative of the conditon and degradation of the fluid, and thus the transmission.Haitian_King wrote:It's a reddish color and smells like ATF. No burnt smell.
No one buys a car and expects to shell out $5500+ during the first year of ownership either.maxnix wrote:It should be bright pink like new. Do the white paper towel test and report back. The visual difference is indicative of the conditon and degradation of the fluid, and thus the transmission.
A luxury imported V8 sedan is not really a budget vehicle for the frugal minded, like students should be.
True in most cases, but I have to say it worked out well for me! I went from king of the 100K extended warranty to driveway mechanic at my parent's house. My DIY abilities, beyond oil changes, came from necessity... that and I thought I had a better chance of getting... well... you know - if I wasn't driving a escort.maxnix wrote:A luxury imported V8 sedan is not really a budget vehicle for the frugal minded, like students should be.
