I have a red 91 Z32 2+2 5 speed. Bought it last week not running. The battery terminals were trashed and battery tested 0.01 lol. It has a new PTU S1 style with adapter all clean. New CAS, new fuel pump, and now a new battery. Checked codes got error 21. "ignition signal circuit " Most would say this points to a PTU. However i did double check connections everything good tight and clean. However they did leave the PTU in the factory spot on the timing cover. So I ohm checked my injectors from my ecu and here as follows;
pin 101 injector 1 tested 10.83
pin 110 injector 2 tested 10.79
pin 103 injector 3 tested OL
pin 112 injector 4 tested 10.75
pin 105 injector 5 tested 10.69
pin 112 injector 6 tested 12.16
Is the OL injector the cause for the code 21? Its still not starting. It should still start with 1 bad injector right? It makes a very odd noise when key is turned "ON" what seems like its coming from the t-tops.
Sounds like maybe my fuel pump is retarted or im going crazy. Last owner said it was getting fuel but no spark. Yet it cut off on him while driving? He said he put a new fuel pump in but maybe thats not true. The PTU and CAS are def new tho. Dont get it. It seems ill have to double check over him. I just dont have the tools right now. Ill make a video of the sound and try to crank it up. Maybe you guys know..
Thanks for your time!
