DevilMB3017 wrote:What's the scale of the graph in the video?
Is the timing shifting a few degrees or 5-10+? A few degrees is very normal.
The MAFS being unplugged and not idling of course isn't. I would start there, because like Eric said, it should be .98V at idle I think it is?
What ECU are using out of curiosity?
its shifting 5-15 deg i've log as low as 4 deg and as high as 26 deg at idle alone.i unplug the maf to see if it idles better and it just dies.i'm using an enthalpy tuned ecu, which has been doing me good for the past 3 years and now nistuned ecu which i haven't put in yet do to the issues i've been having.
i went to do a compression and leakdown test and found #3 and #4 plugs to be oil filed. i changed them and it idled good for a few min then the rough idle came back (3 and 4 filed again). the compression test on a cold motor showed 150 psi across the board dry and 150 across the board with a cap of oil in each cylinder ( rings are good) i just changed the valve seals about 2 months ago do to smoking on start ups, which its doing again along with oil now leaking from where my exhaust meets the head. so the only thing left is either head lift or valve guides. pull the head last night and head gasket looks good and the head is now at the shop getting a overhaul. I'm sure oil getting mix with my fuel along with filing spark plugs would cause a bad idle and erratic timing. hope thats all it was. thanks for the help fellas.
