Oh, and in reference to the above: definitely feels like the car is driving me, rather than the other way around. If what you describe as "loose steering" is actually the definition of it, I would say that is not my problem. In fact, it seems as if there is too little effort needed to turn the wheel. At least, less than I remember there being when I bought the car.Sentientbydesign wrote:I would be it's your alignment.
If they've done an alignment on it and it's still producing the same problems, my next check would be the tires.
I'm not sure how much you drive, but these tires usually don't last long.
My first set of worn tires caused some very erratic pulling when I hit potholes or bumps. New tires and an alignment made things much better.
To better clarify. Does it feel like your steering is loose or like the wheels are steering you instead of the othe way around?
Loose steering would be you turning the wheel and the car not moving or moving eventually.
Thanks for this lead. The TSB, if anyone's interested, is ITB08-046. I have complained of "wander" since day one. My "old" dealer won't check the alignment, claiming a slight curb kiss when pulling into a parking space at less than 5 mph caused my complaint (even though I first complained prior to any of this).geoff_diamond wrote:I've got about 12K miles on the car - the tires look to be in fine shape to the untrained eye, but, that's not to say there isn't something going on with them.
I did read up on the TSB relating to steering issues for all Infiniti model numbers (dated 10/9/08) - VERY interesting stuff - seems to describe my problem fairly accurately.
I don't want to come off as being the divine dictionary, but that's always been my understanding.geoff_diamond wrote:
"bump steering" is normally caused by bad ball joints or a loose control arm. The upper fails 2/1 vs the lower.notalk wrote:
I assumed I had too much toe out, possibly caused by overtightening the front axle hold down straps during shipping. I figured a good alignment after getting replacement tires would cure this. Please let us know what your dealer says/does. I'll ask my "new" dealer to keep an eye on this TSB.
This isn't bump steer. It's wander, where the car wants to go left or right for no cause or reason. Usually, this is an indication of toe out, where an uneven road surface will cause the car to start into a turn. Or, tires which have worn enough to cause the car to want to go into a turn. The FM chassis is particularly susceptible as Nissan wants zero toe or slight toe out to overcome the natural tendancy of the FM chassis to hesitate to start a turn.gwoods wrote:
My money is still on upper ball joint or upper control arm
notalk, that is not something an alignment can fix.geoff_diamond wrote: It's akin to when you hit a rut or uneven patch in a roadway - the car sort of takes the wheel out of your hands.
SO??????geoff_diamond wrote:I've got about 12K miles on the car - the tires look to be in fine shape to the untrained eye, but, that's not to say there isn't something going on with them.
I've got a service appointment (again) in the morning and will be sure to keep everyone posted on what I learn! Thanks, again, for all your help!
I disagree. I had very similar symptoms and mine went away with new tires and an alignment.gwoods wrote:
The wandering at speed, could be tires or alignment
Have to agree with Nate.A bad alignment can make a car squirrelly as hell. Sounds like something may have come loose.....Sentientbydesign wrote:
Could be different causes with similar symptoms, but I still think it's out of alignment.
Please don't go to the dealer and Tell them what to do, you may not agree with your advisor but they do know they product, I am not bashing you Jacko that is just a bit of a pet peeve of mine.Jacko3 wrote:Also, don't forget to tell them to retorque every bolt on the control arms.
Anyway, car's still at the shop - so, no updates as of yet. I don't believe they've rotated the tires at all (they're directional, right?). As far as walking you through the problem - it feels just like hitting a rut... I'm not sure how else to explain it? I mean, I'm not sure if an alignment issue would cause steering issues in both directions, would it? I was always under the impression that if your vehicle was misaligned, it would only wander one way or another. The only other bit of pertinent information that I can think of is that the problem doesn't really seem to creep up when I'm deep in a turn - it's only when I'm driving straight or just barely off-center (ie - changing lanes).SteveTheTech wrote:Welcome to the group!
I know that the tires cannot be traditionally rotated but have you had them cross rotated in the 12K that you have on the car?
The alignment and tires are covered (I think) for 12mo/12,000 mi so they should have warrantied pretty much any complaint you have.
ITB08-046 pertains to road crown and lead conditions that have been raised by owners due to the car changing lane in a specified amount of time. This is something I have noticed a lot of the members with Ms complain about more than many other Infiniti members. Even if your alignment is perfect (which very few are) and the tires have been in the same position as they came with they will cause ride comfort issues.
Since I am not able to drive your car you will need to walk me through it a bit. You say the steering is feeling funny, can you be more specific as to what exactly it is doing.
If this were my car and I had to give it to someone else to fix I would ask if they have the Hunter Straighttrack Road Force Balancer (the most amazing tire balancer) and I would want to have an alignment done and want to see the numbers. If you have a scanner handy, post it and we will review it
I highly doubt it is a mechanical part issue, I do not think it is any of the ball joints, as you would notice a noise or vibration in the steering wheel before most ride issues were noticed. Especially when the suspension/steering is as tight as it is in the 37.
I'm sure the SAs at your dealership are top notch, but be forewarned that I've dealt with a large handful who know very little about the vehicles they service (or advise about).SteveTheTech wrote:Please don't go to the dealer and Tell them what to do, you may not agree with your advisor but they do know they product, I am not bashing you Jacko that is just a bit of a pet peeve of mine.
as much as I hate being wrong glad your car is fixed.geoff_diamond wrote:Okay. So, got the car back yesterday afternoon. Naturally, my secondary display now insists that it's 36-degrees and Icy at all times - but, that's an entirely separate issue.
So, my SA told me that the alignment was off and has been adjusted and also said that they made some adjustments to the camber (I'm not sure on which wheels, or in which directions). All in all, I would say that the problem feels a bit better, perhaps 30-40% better if I can try to quantify these things. But, I swear, it still doesn't feel like it did when I bought it.
Anyway - I appreciate all the help that everyone here was able to offer and I'll certainly keep everyone informed of any future developments!
