/ erratic outside air temperature readings /
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
williammoses
Car: 2011 Infiniti EX35 Journey AWD
In recent weeks, I have noticed that the outside air temperature readings in my 2011 EX35 have become somewhat erratic. By erratic I mean the following:
1.) The vehicle's outside air temperature reading is as high as 10 degrees (F) hotter than the true ambient air temperature, even when car is moving about 45 mph. When the vehicle is moving at this speed, outside air temperature reading should not be affected by engine bay heat.
2.) Even though the ambient air temperature is constant, the vehicle's outside air temperature reading can vary about 6 degrees within two or three minutes. Where I live (Washington, DC) the ambient temperature is rarely--if ever--so variable.
During the first six months of ownership, the vehicle's outside air temperature readings were accurate and notably stable. Is the outside air temperature sensor subject to malfunction on EX35's? I have searched the website and have found only one or two references to erratic readings.
dru19
Car: 2010 EX35 AWD with Nav, Premium, All around view packages (Black/Black)
Actually, I noticed that just yesterday on my 2010 EX35 Journey. The temperature jumped from 92 to 105 as I was driving through Boston city traffic. It returned to mid 90s about 10-15 minutes later. This is the first time I have seen that issue, but if it happens again, it might be a sensor issue.
williammoses
Your observations appear to be remarkably similar to mine. Let's see what others have to say.
sashki2
Car: Altima 3.5SE Coupe Manual Transmission
Infiniti EX35
I think it's a nissan thing. Temperature reading on my EX & on my wife's Altima were always incorrect, higher then normal. I don't know where temperature sensor is located. Possibly it's too close to some hot part.
txgcoupe
Car: 2007 G35 Coupe/ 2010 EX35
Most cars work that way.
If I'm in the car and comfortable... I could care less what the actual temperature is.
John
williammoses
The accuracy of the outside air temperature indictor is important to those who drive in cold climates. It is helpful to know when the ambient temperature drops to 32 derees or less, because water on roads begins to turn into ice at that temperature. Cars easily lose traction on, and there a different driving technique is required. The outside air temperature provides critical information to the driver.
sashki2
Infiniti EX35
the temperature sensor worked fine in my Subaru.
It's very useful to know that someone could care less about correct reading though :). It would probably be equally useful to to know what I think: if a device is built-in in my car & therefor paid for, it should work right.
dru19
Update on my original observation. The issue has not repeated itself since I noticed it the first time. It could be due to the fact that the weather has been a lot cooler last few weeks.
BigP
Car: 2006 M45
We just bought a 2010 EX35 and I have noticed the same thing (temperature readings of 105 when it is 85-90 outside). My M45 is always within 1-2 degrees of what the radio weather dudes say.
ewitz
If the sensor is close to the asphalt the temperature could be significantly higher than the ambient temperature.
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
As sort of mentioned before, maybe we need to locate where the Sensor is?
Avalanche325
Car: 2008 EX35
1965 427 SC Cobra (Factory Five Racing)
Mine (2008) seems very steady and consistant. Was it wet out when you saw the variations. The sensor is under the hood lock assembly, so probably high up for puddles.
I have noticed less "high when stopped" readings than in other cars I have owned.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
