Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Dec 30, 2008 6:48 am
Important to view CAS outputs at high rpms with a digital oscilloscope as the 360 - 1 degree optical signals have a way of getting ragged from oil vapor/dirt as they age.
The ecu has a backup from 90 degree magnetic sensor but sometimes you get hiccups especially above 3,000 rpm.
I replaced my CAS with a brand new unit around 250k [13 years] and the problems went away, unfortunately the unit cannot be dissassembled fully for cleaning. The J30/300zx has similar high mileage problems.
The 1 degree firing accuracy of the coil on plug system resulted in ~~ 10 HP gain above 6,000 rpm and is necessary at 7300 rpm. Especially with reprogram where 2-3 degrees of advance are added to add power.
Research spark plug/distributor scatter inthat each must be EXACTLY 90 degrees apart for perfection.
This GM pdf is a good read to understand the accuracy required:http://porschehybrids.pbwiki.c...k.pdf
