ERG Replacement Bolt Size?
greendusk
Car: 1990 300zx TT Pearl Glow (5 Speed now after swap)
1990 300zx NA Black Auto(Sold)
1990 300zx NA Purple 5 Speed(Engine Washed /Sold)
2001 Stratus (Scrapped)
I have not delete my EGR and I pulled the plenum last weekend. We lost the bolts for the ERG (all 4 of them.) and I want to know what I could replace them with also if not have them in would make me lose Vacum.
es.biggs
Car: 1990 300ZX 5sp NA
You won't lose vacuum without them, but it will be rattling all over the place and that's usually a bad thing. You can try taking random bolts out of other things to find one that fits the threads where the egr mounts up. Shouldn't be too hard the whole engine uses just a few bolt/thread sizes.
You could delete the EGR...have you thought about doing that?
You can also order the bolts from courtesy nissan - but that is probably your most expensive route and it will take a while for them to come in. Local dealership may have the bolts, and if not, they may be able to give you the right sizes so you can pick some up at a hardware store.
nissanfreak12
Car: 92 300zx 2+2 TT
6mm 1.25 pitch, not sure how long, exactly same bolt as your fender without the washers
es.biggs
haha oops I thought you were talking about the bolts for the EGR valve, not the tubes. Ya you definitely need them because it'd be a massive vacuum leak.
nissanfreak12
NOw im second guessing myself, it may be 5mm by 1.0 thread, but i do know its the same size as fender bolts or even the nose cover, air filter cover
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
nissanfreak12 wrote:NOw im second guessing myself, it may be 5mm by 1.0 thread, but i do know its the same size as fender bolts or even the nose cover, air filter cover
They're M6 bolts.
nissanfreak12
Haha! So i was right on the first one :werd:
