Tictakman »
https://forums.nicoclub.com/tictakman-u2357.html
Sun Jan 25, 2004 8:25 pm
this thread was over on 240sxforum.com. just wanted to know if it was true. i could use the bung for the egt gauge instead, right?
Zak
What will happen if its not connect to the downpipe?
It will open, and suck air into the intake at part throttle operation, making the car very lean. You can cap it and you not have any problems. Take it off and weld it closed, or bent the pipe and squeeze it shut.
what if I dotn have it connected on the intake as well so it cant put air back in?
if i just cap it off at the header will i run funny during partial throttle?
no...as long as there is no foreign air entering the intake(foreign meaning it isn't read by the MAF) then you're fine.
and if i dont cap it off then foreign or are you reffering to the vacuum hose location
