There she is ripe for upgrades
I didn't have no compression, it had low compression in 3 cylinders ( I guess I could have worded my statement above better) . The rings seem to be the culprit. The whole engine is broken down at the moment and the pistons look good now that they have been cleaned and checked. The new rings are in hand and this weekend the engine will be put back together. We are going to perform leak checks on the valves , the works. We were initially worried that maybe the pistons were screwed but after the engine was opened up it was all good. Just really carbon caked with bad rings.Carl H wrote:did you figure out why the motor had no compression?
normally these motors will chew up the ringlands and render the pistons useless if the problem is piston related...might want to make sure the head isnt fubared.
Holy crapOrthank wrote:
Orthank wrote:This is kind of good because it gives us a chance to tackle the bodywork.
I have owned 4 Skylines. 2 r32s and 2 r34s. Any r32 that has not seen an accident will be in way better condition than an r34 that also has not seen an accident. The proof is on the bottom of the car. They stopped putting under coating on the entire body of the skyline after the r32 and the rust damage became quite shocking once the aero was off my car.
It is no where near as good as the 32. I have looked at many 34s and many 32s and generally the 32s are always in better shape.Miguelone wrote:Orthank wrote:This is kind of good because it gives us a chance to tackle the bodywork.
33's and 34's do have undercoating underneath, You live in a coastal area and the previous repairs probably weren't done to the highest of standards which both would have contributed to your rust issues, I've had 2 33's and worked on numerous 33's and 34's and none have had any significant rust damage anywhere.
